Gaming PC Build Help
You can overclock a 4690k to 4790 speeds (4.0 Ghz) and a lil bit beyond saving about $68..... add on a $65 Phanteks PH-TC14PE cooler which tops the Hyper 212 by 7-10C and you get 4.4 - 4.6 GHz for less. With the Hyper 212, you'll save $30 but 4.2 to 4.4 GHz is more typical
I'm not familiar with a D8 case.
As for the 970 versus 280x ... it's 30% faster produces less heat with less power
PCPartPicker part list...
1. It's hard for me not to advise against a non k processor.....4690k can be overclocked to 4790k stock levels saving $90 ... but of ya not overclocking .... the 4790 makes more sense.
2. I like the MSI G45 over the Giga but I don't feel strongly about it.
3. 2133 CAS 9 RAM is just $4 more than your 1600 in same color... $3 in blue
4. The Seagate SSHD has a built in SSD and is $11 cheaper
http://www.tomshardware.com/charts/hdd-charts-2013/-17-PCMark-7-Gaming,2915.html
http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dx001
5. HUGE quality upgrade, more power for $2 more
http://pcpartpicker.com/part/seasonic-power-supply-s12ii620bronze
6. If ya go for the 4690k and OC, you could move up to a MSI 970
I assume you have a case.
A 3rd party cooler would normally be recommended but of you are not overclocking, it's just wasted money.
The i5 is enough for gaming. The i7 is a bit of overkill... Different / cheaper motherboard, better memory, better GPU, cheaper / faster HD... No case in your original build? If you could squeeze in an SSD (Crucial MX100) you would be a bit better off, but that is optional.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($115.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($64.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($328.99 @ Directron)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($83.98 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($58.99 @ SuperBiiz)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($14.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($97.75 @ OutletPC)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($28.98 @ OutletPC)
Headphones: Thermaltake eSPORTS SHOCK Battle Edition Headset ($49.54 @ Mwave)
Other: Xbox one controller
Total: $1143.12
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor ($286.88 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-Gaming 3 ATX LGA1150 Motherboard ($125.99 @ SuperBiiz) - try H97 instead
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($70.89 @ OutletPC) - try 2 x 4gb 1866 cl9 for same price
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 280X 3GB Tri-X Video Card ($242.98 @ Newegg)
Power Supply: Inwin 550W 80+ Bronze Certified ATX Power Supply ($66.99 @ Directron) - try XFX550 instead - $53 - http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($87.75 @ OutletPC)
Headphones: Thermaltake eSPORTS SHOCK Battle Edition Headset ($49.54 @ Mwave) - Try Plantronics Gamecon 780 instead $60 - http://www.newegg.com/Product/Product.aspx?Item=0TH-000R-00020
Total: $1064.97
Oh, I must have removed it to find another one and forgot, forgot about the xbox thing too xD; Why a gtx970 over the R9? just curious.
I forgot to add a case D8 but I wasn't planning on overclocking unless you think thats better?? I play a lot of minecraft and i'm sure other things in the future that require more than I have right now, but yeah.
PCPartPicker part list: http://pcpartpicker.com/p/KVfzjX
Price breakdown by merchant: http://pcpartpicker.com/p/KVfzjX/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.89 @ OutletPC)
CPU Cooler: Phanteks PH-TC14PE 78.1 CFM CPU Cooler ($64.99 @ Newegg)
This pairing will give you 13% faster speeds for a buck less
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($129.99 @ Micro Center)
Again, Giga choice is fun but easier to deal w/ tech support if MoBo and GFX same
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($74.98 @ OutletPC)
Who do 1600 when ya can do 33% faster with 2133 for $3-4 ?
Storage: Seagate 1TB 3.5" 7200RPM Hybrid Internal Hard Drive ($78.98 @ OutletPC)
SSD + HD in one unit boots in 16.5 seconds to SSDs 15.6 seconds
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($349.99 @ NCIX US)
Consensus choice 970
Case: Phanteks Enthoo Pro ATX Full Tower Case ($109.99 @ Amazon)
Superb case
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($70.98 @ Newegg)
Allows addition of 2nd GFX card at later date to extend system life 18 - 24 months
Total: $1099.79
Generated by PCPartPicker 2015-02-18 15:52 EST-0500
Try and buy the OS on campus .... my son;s have bough em from $10 - $25
OH uh D8 is a emoticon face, sorry.
So you'd just trash the fan that comes with the cpu and use the one you buy if you're overclocking?? do you have to buy extra fans for the case it self? thanks for answering my questions by the way.
High quality parts and a focus in strong gaming performance:
PCPartPicker part list: http://pcpartpicker.com/p/pWtGNG
Price breakdown by merchant: http://pcpartpicker.com/p/pWtGNG/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($179.59 @ SuperBiiz)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard ($84.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($44.99 @ Best Buy)
Video Card: Sapphire Radeon R9 290X 4GB Tri-X Video Card ($323.98 @ Newegg)
Case: NZXT H230 (Black) ATX Mid Tower Case ($54.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($79.99 @ SuperBiiz)
Total: $1019.77
Generated by PCPartPicker 2015-02-18 15:55 EST-0500
1st - see my edits above.
Yes, you just put the stock cooler back in the box.
Hyper 212 is good for moderate overclocking and costs $30
Phanteks cost $60 - $65 depending on the day you shopping and gets you 7 - 10C more cooling.
4790 = 4.0 GHz
4690k w/ Hyper 212 = 4.2 - 4.4 Ghz
4690k w/ PH-TC14PE = 4.4 - 4.6 Ghz
4690k w/ H220-X = 4.6 - 4.8 Ghz
Oh thanks, buy it on campus? from other people or from the campus store?
