Question Gaming PC Configuration help required
Mar 25, 2019
4
Hi Friends,
I am planning to build a pc with below configuration. It suits my budget. Please suggest if these are compatible, or will it perform well.
  1. CPU - AMD RYZEN 5 1600 Desktop Processor With Wraith Spire Cooling Solution -
  2. Power Supply - CORSAIR CS450M SMPS - 450 Watt 80 Plus Gold Certification Semi Modular PSU
  3. HDD - WESTERN DIGITAL DESKTOP HARD DRIVE 1TB BLUE (WD10EZEX)
  4. SSD - WESTERN DIGITAL Green 120GB Internal SSD (WDS120G2G0A)
  5. RAM - CORSAIR CMK8GX4M1D3000C16 Desktop Ram Vengeance Lpx Series 8GB (8GBx1) DDR4 3000MHz
  6. Graphics card - ASUS ROG Strix Gaming RX 570 OC Edition 4GB GDDR5 Graphics Card
  7. Motherboard - GIGABYTE B450M DS3H Motherboard (Amd Socket AM4/Ryzen 2nd Gen Series CPU/Max 64GB DDR4-3200MHz Memory)
  8. Cabinet - COOLER MASTER ELITE 311 (ATX) Mid Tower Cabinet - With Usb 3.0 (Red-Trim)
Feb 26, 2019
21
Hello, I saw your build and the cpu you`re going would run very bad on a single channel ram slot, get 2 sticks of 8 gb ram 3000mhz or up if possible, it will give you much better performance. I upgraded your RAM, CPU and GPU aswell as the case and power supply. The build will get your games running on medium to high settings.
https://pcpartpicker.com/list/BTWDWD
Mar 25, 2019
4
Thanks jAAklis for taking your time to suggest changes. But, the config you suggested is out of my budget, thats why i am going with 570 instead of 580 gpu.
Will just adding a 8gb ram to my build will make it perform better?
Feb 26, 2019
21
Yeah get 2 sticks of 8gb ram 3000-3200mhz and upgrade the cpu to ryzen 5 2600 your build will last longer and it will perform much better than the ryzen 5 1600 with the ram u have.
