Approximate Purchase Date: This Week.
Budget Range: Around $900 Can spill over if parts are really worth it.
System Usage from Most to Least Important: Mostly gaming, with occasional movie watching.
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg.com please! I just want to buy everything at once on one website.
Parts Preferences: AMD
Overclocking: Yes
SLI or Crossfire: Maybe
So I already did some research and began putting some parts together to try to make a decent gaming pc and this is how far I've gotten:
CPU: AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ ($139.99)
CPU Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 ($34.99)
Motherboard: ---------------
Memory: Mushkin Enhanced Redline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) ($79.99)
Storage: Western Digital WD Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive ($99.99)
Video Card:----------------
Case: COOLER MASTER CM Storm Scout 2 ($99.99)
Power Supply: CORSAIR Enthusiast Series TX650M 650W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Semi Modular High Performance ($104.99)
Optical Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM ($19.99)
OS: Microsoft Windows 7 Home Premium SP1 64-bit - OEM ($99.99)
Total: $674
**So with that I have a couple of questions that I was wondering that anyone could help me with:
1. What would be the best MoBo for this setup in the range of $100-200?
2. What video card would be a good choice?
I was looking at-
--XFX Double D FX-787A-CDFC Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
and
--ASUS HD7770-2GD5 Radeon HD 7770 GHz Edition 2GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Both have great reviews but what do you guys think? Are they worth it? Is there something better in in the $200 range?
3. Finally I would just like to ask if the power supply and/or memory are overkill? Because they are a little costly and I don't know if theres something out there that is cheaper but equal quality.
If I can get a few opinions then that would be extremely helpful. I'm new to this and i really want to get a gaming pc going soon so any input is greatly appreciated 😀 So thank you!
Overclocking: Yes
Total: $674
I was looking at-
and
