I'm looking for some advice on my current PC/parts related dilemma.
My current PC was damaged by a power surge resulting from a power outage across my suburb not long ago. Returning from work, I powered it up and found that nothing was displaying on my monitor (it recognised that the HDMI cord was plugged though - it just said no signal). I thought the GPU may have been damaged, swapped an older GPU in and found the exact same thing.
A local PC technician had a look and said the motherboard is almost certainly dead, but that the CPU and PSU might be damaged as well, but it'd be hard to tell without a functioning board.
He recommended replacing all three parts.
The issue is is that a lot of the components are close to three years old, and were starting to become dated (except an aftermarket GPU). The board, CPU, and card are all AMD - whose overall performance I find frustrating (driver updates etc). It wasn't a horrible or slow setup, but I'd turned my mind to upgrading or updating entirely and going Intel/Nvidia.
It seems I have two options:
1. Replace the damaged components with Intel CPU and board - and new PSU. This will require new RAM and a new CPU cooler - the cost seems to just keep adding up. I also don't know if there might be other components that have been damaged?
2. Buy a new system - I've been looking at Pccasegear and Mwave. Any Aussies, do you have opinions on either? Also, I'm torn on whether it's worth getting a system with a GTX980 or a 980 Ti. I only play on a 1080p monitor, and I don't mind if I can't hit ultra and 60fps - but, if I'm buying a new system I want longevity before needing to upgrade parts etc. Any advice there would be appreciated too.
That's the situation - any advice or experiences would be much appreciated.
Cheers!
Cheers!
