Gangster motherboard solution
Chapel
45
I discovered that my thumb screws fit my motherboard. From the looks of it they also make the same amount of contact as any other normal motherboard screws. So my question is; should I use one to replace a worn out mobo screw?
-Chapel
prong
253
-Chapel
Sounds like you screwed your MB to death.
