Question Garbled/static sound after rebuilding PC
Dec 22, 2020
4
I rebuilt my computer & only kept the hard drive. I also added an old hard drive as my 2nd one (it's from 2009). Everything on it works except the sound. I've followed all directions on every site I can find + YouTube video.
  1. Running the troubleshooter
  2. Reinstalling Realtek audio driver
  3. Resetting back to original
  4. Reinstalling it from the website, reinstalling it from the hard drive.
  5. Restore defaults
  6. Disabling hardware enhancements.
  7. Changing the MHz that it plays at to all available frequencies
  8. Changing my power plan to high performance (making sure I had 100% on all settings)
  9. Resetting my PC
  10. Trying diff USB, speakers
I ran Latency Mon on my computer & it says I have a latency issue. It tells me to change stuff in the bios but I looked into my Bios settings from my manufacturer & there are no settings that match what I should be doing. I attempted overclocking but it failed & auto reset back to defaults. There was latency settings I changed, that failed.
Windows 10 Ver 20H2 (OS Build 19042.928)
Old Build:
Motherboard - ASRock FM2A68M-DG3+
CPU - A6-6400 APU
Ram: 8 GB
Graphics Card - Nvidia GT 740
New Build:
Motherboard: MSI B365M Pro-VDH
CPU - Pentium Gold G5500
Ram: Samsung 16 GB DDR4 PC4-21300 2666 MHz UDIMM
Graphics Card - Gigabyte RX 570 4 GB
I ran latency mon & this is what I got: Could someone explain this in English please? It seems to confirm that Realtek is the issue. It's telling me to do something with power throttling but when I google that, it shows for laptops. This is a desktop. All of my power throttling options show disabled. (Note to self & others: I'm going to leave this here & go to the next app on the list & also check the BIOS settings to see if there is something to be done there. Will update if so).
____ _
CONCLUSION
____ _
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:06:04 (h🇲🇲ss) on all processors.
____ _
SYSTEM INFORMATION
____ _
Computer name: PC
OS version: Windows 10 , 10.0, build: 19042 (x64)
Hardware: MS-7C39, Micro-Star International Co., Ltd., B365M PRO-VDH(MS-7C39)
CPU: GenuineIntel Intel(R) Pentium(R) Gold G5500 CPU @ 3.80GHz
Logical processors: 4
Processor groups: 1
RAM: 16326 MB total
____ _
CPU SPEED
____ _
Reported CPU speed: 3792 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
____ _
MEASURED INTERRUPT TO USER PROCESS LATENCIES
____ _
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 3061.80
Average measured interrupt to process latency (µs): 7.231047
Highest measured interrupt to DPC latency (µs): 2604.30
Average measured interrupt to DPC latency (µs): 1.985233
____ _
REPORTED ISRs
____ _
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 3057.904008
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.010917
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.011974
ISR count (execution time <250 µs): 12221
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 14
ISR count (execution time >=4000 µs): 0
____ _
REPORTED DPCs
____ _
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 8488.567511
Driver with highest DPC routine execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Highest reported total DPC routine time (%): 0.115744
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.226680
DPC count (execution time <250 µs): 348365
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 24
DPC count (execution time 1000-1999 µs): 16
DPC count (execution time 2000-3999 µs): 18
DPC count (execution time >=4000 µs): 0
____ _
REPORTED HARD PAGEFAULTS
____ _
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 664
Hard pagefault count of hardest hit process: 281
Number of processes hit: 24
____ _
PER CPU DATA
____ _
CPU 0 Interrupt cycle time (s): 10.249185
CPU 0 ISR highest execution time (µs): 3057.904008
CPU 0 ISR total execution time (s): 0.170324
CPU 0 ISR count: 10369
CPU 0 DPC highest execution time (µs): 3103.871835
CPU 0 DPC total execution time (s): 2.965192
CPU 0 DPC count: 313914
____ _
CPU 1 Interrupt cycle time (s): 1.824411
CPU 1 ISR highest execution time (µs): 139.896624
CPU 1 ISR total execution time (s): 0.004156
CPU 1 ISR count: 1866
CPU 1 DPC highest execution time (µs): 2297.635549
CPU 1 DPC total execution time (s): 0.107874
CPU 1 DPC count: 10825
____ _
CPU 2 Interrupt cycle time (s): 2.153153
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 8488.567511
CPU 2 DPC total execution time (s): 0.158756
CPU 2 DPC count: 15665
____ _
CPU 3 Interrupt cycle time (s): 1.256402
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 2243.531646
CPU 3 DPC total execution time (s): 0.071191
CPU 3 DPC count: 8021
__
I should also note that my mic doesn't work sometimes either. Although I am getting a very small about of sound output from the mic now. Screaming into it is giving me about a 5-10% bar.
