So I'm looking on the bestbuy website and I find what seems to be a great monitor..
http://www.bestbuy.com/site/olspage.jsp?skuId=8550588&type=product&id=1188560797577
It has every imaginable input that you could desire for any system or whatever. A very low refresh rate of 3ms. PIP so you can check out several inputs at once.. A hot 1920x1200 native resolution. Full 1080p support. I mean this monitor has to be to good to be true!
So I'm like ok ill search around for some reviews.. What do I find? NOTHING! I even noticed that tom's hardware which has been the site to go to for a good review for who knows how long now. Has no reviews! Not just that, but it seems tom's hardware hasn't done any reviewing for a while. They are very behind the times with a lot of topics and computer components.
That being put to the side. I'd like to hear some feedback on this monitor. I wana know the nitty gritty. The good, the bad, and the ugly. Why is it I havn't seen anything on this monitor? Its almost like it doesn't exist. From what I have seen is that anyone that has found one at their bestbuy has only ever had 1 in stock.. (Same with the one near me) If it would be possible I'd like to hear some type of review of this monitor, and soon before that last one is gone!
Also is there anyone out there that currently owns one? If so and you know a bit more about monitors please make a post. Posts like "Monitor is great!" or something simular wont help any. I already know the monitor seems great. I want to know what the cons are to this thing.
To anyone with anything I thank you in advanced, also this should be a good spot to find some information of this monitor, because apparently I'm the only one that cares enough to want to find out.
