So I'm looking at this monitor, "gateway fhd2303l 23 inch lcd-led monitor" at best buy http://www.bestbuy.com/site/Gateway+-+23%22+HD+LCD-LED+Widescreen+Monitor/1757344.p?skuId=1757344&id=1218289375285
at first glance i thought this monitor was definately led, because i found it in the led monitors section in best buy and it also says lcd-led in the name/descript of it which from my understanding means its led(because led is also lcd, yes i know...floursent lighting etc.)
but then when i click on specifications it says "Monitor Type: Widescreen flat-panel LCD"...which just blows my mind
I then went on to looking at some other led monitors categorized in the best buy website, and when i go to specifications, some say the same "widescreen flat-panel LCD" while others says LED monitor
also some monitors are titled directly at the top LED monitor while the gateway monitor im looking at is titled "Gateway - 23" HD LCD-LED Widescreen Monitor"....with LCD-LED apparently having a different meaning as LED?
well anyways if someone can clarify this that would be great, bottom line is i want to know whether this specific gateway monitor fhd2303l is LCD or LED
