Gateway FX6801 power switch connection??
drdelp
6
on the FX6801-01, can anyone tell me which 2 pins on the FP1 connector does the power switch connect to?
drdelp
6
nikorr, thanks for replying to my post, I appreciate your time and input. My concern is that the Gateway FX6801 motherboard is propriatary, the FP1 connector has no labels, and from the factory, the only connector attached to it was the 2-wire power switch (all other front panel functions are fed from the USB connectors on the motherboard and go up to an enclosure at the front-top of the case.) UPDATE: I just took a chance, and jumped the 2nd set of pins (from the right), and it works; problem solved. Thanks very much, drdelp
fibercarbon
13
im having the same issue i took out my motherboard to clean it on my gateway FX6801-03 and i cant find where to plug the 2 pin RED and white cable Power Switch connector onto the motherboard.. there is no label on my motherboard anywhere for it...... ughhhh i tried for like 5 hours to find it with no luck..http://www.seeedstudio.com/blog/wp-content/uploads/2011/11/JST-2-pin-Power-Connetor.jpg
:cry: :cry: :cry:
fibercarbon
13
anyone please help!! i really need to find the spot on the motherboard for my gateway fx6801-03, to plug :whistle: the front power switch into.. i use my computer for work so i need help Urgently! any help is very much Appreciated
drdelp
6
The 2-wire power connector attaches to the white header on the lower edge of the motherboard (about 1 inch from the lower right corner); It is attached to the 2nd pair of pins from the right of the header, closest to the edge of the MB; see image
i42.tinypic.com
; hope this helps. drdelp
