Gateway M1300 TabletPC & Linksys WRT54G: WLAN Connection D..
G
Guest
Guest
Archived from groups: microsoft.public.windows.tabletpc,microsoft.public.windows.networking.wireless (More info?)
I am cross posting this to both the Tablet PC and Wireless newsgroups - not
sure which is most appropriate.
My Gateway M1300 connects via wireless to a Linksys WRT54G wireless router.
I've found that the connection will drop, all of the sudden, and the router
can not be found. Then after a few minutes, or seconds, it will re-establish
a connection. Sometimes it won't and I have to reboot the router.
Now, this has occurred with and without SP2 installed. Prior to implementing
the WRT54G, I had a 1st gen Linksys wireless router (BEF11W???) which also
displayed the same behavior. In fact, that's why I replaced it with the
WRT54G - thought it was a defective router.
Interestingly, my Dell laptop (Win2K, using a Microsoft wireless 802.11 B/G
PC card) also has the same behavior, whether it was with the old or new
Linksys router. But I rarely use the Dell at home, so my focus is on the
M1300.
I think that a recent Windows update, or some common software to both the
Dell and the Gateway, or maybe even a router configuration issue, may be the
root of the problem.
I seem to recall reading somewhere that a Windows hotfix caused a similar
issue.
Ideas?
Thanks,
David
G
Guest
Guest
Hi David,
Since the connections are dropped with two different clients, I would
suggest that you check on the Linksys site for firmware updates for the WRTG
54
General Downloads page: http://linksys.com/download/
I found a recent firmware update 8/4/2004
http://linksys.com/download/firmware.asp?fwid=201
> M1300.
> issue.
> Ideas?
> Thanks,
> David
cadman
11
You might try changing the channels. Move away from the default 6. Other
devices such as cordless phones can cause problems like you describe. I've
had these problems at home with tablet pc, wireless laptop, and pda both
adhoc and infrastructure mode. I switched channels to 1 and got steady
connections. I have 4 cordless phones located throughout the house, working
from one base.
"David Lipetz" <dlipetz@hotmail.com.invalid> wrote in message
news:OXMeIA3iEHA.384@TK2MSFTNGP10.phx.gbl...
not
router.
router
re-establish
implementing
B/G
> M1300.
the
> issue.
> Ideas?
> Thanks,
> David
G
Guest
Guest
Thanks. Already did that upgrade.
After reading around a bit, I suspect that it may be my 2.4GHz cordless
telephone that may be causing the drops. The base station for the phone is
in the same room as the WAP. Will change the channel on the WAP to see if
that helps.
"WNewquay" <WNewquay@discussions.microsoft.com> wrote in message
news:B7DA286E-C18B-4BA9-BF4E-73B4AEC2E55A@microsoft.com...
> Hi David,
WRTG
> 54
not
router.
router
re-establish
implementing
also
B/G
> > M1300.
the
the
similar
> > issue.
> > Ideas?
> > Thanks,
> > David
