Need some advice on whether I should get a gfx card or not... I just purchased a Gateway sx2802 quad core with windows 7, it has the integrated intel x4500 chipset. That chipset is supposed to support dual independent monitors. I currently have on 22" monitor hooked up and I am looking to add a second. The computer has both a vga and a dvi hookup so I am guessing that should not be a problem.. I do not do any gaming, it is used strictly for application development. So, long story short, will the intel x4500 be enough to push both monitors, or do i need to look into a low profile gfx card. Thanks for the help.
