S sittoo Commendable Oct 9, 2016 34 0 1,530 Oct 9, 2016 #1 Does anyone know what motherboard the Gateway ZX6980 uses and what proccers i can use? (edit) can i use a 1151 cpu?
Solution COLGeek Oct 9, 2016 The ones I looked up use Socket 1155 CPUs. That means you cannot use a Socket 1151 CPU.
COLGeek Cybernaut Moderator Apr 6, 2009 59,526 5,292 184,340 Oct 9, 2016 Solution #2 The ones I looked up use Socket 1155 CPUs. That means you cannot use a Socket 1151 CPU. Upvote 0 Downvote Solution
S sittoo Commendable Oct 9, 2016 34 0 1,530 Oct 9, 2016 #3 Thank you!!! is there anyway i can add a gpu to it? (Its a all in one computer) i was thinking of adding a gt 730 is it possible? Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 59,526 5,292 184,340 Oct 9, 2016 #4 Sorry, but it does not appear to have upgrade-able graphics. That is a major drawback of all-in-one systems. Upvote 0 Downvote
