[SOLVED] GE 75 Raider 10SF Undervolt help
Dec 29, 2020
Good day fellas, Today I bought my 2nd gaming lap top That one
I could not find any good info in web regarding undervolting of Core i7-10875H
Wanted to ask if someone has same model and uses undervolting, i don't have experience in that,
before this one i used acer predator 300, and have just downloaded Throttlestop configuration file from one of forums which worked perfect
Thanks in advance
Check post #4.
They locked that down. You can not undervolt the new 10th gen CPUs because of the Plundervolt vulnerability. You can check it out here https://plundervolt.com
That said, you should have an alternative:
Windows Search > Edit power plan > Change advanced power settings > Processor power management > Maximum processor state.
Try 98 or 95%, apply, then exit.
But iv seen videos how to unlock the bios and undervolt on 10750H ? even after unlocking in bios it is still locked?
