GeForce® GTX 1050 Ti Windforce OC 4G Pin Connection
Psydwell
13
Does GeForce® GTX 1050 Ti Windforce OC 4G needs molex to power it up and if so how many pin does it need?
Thanks
So which 6 pin connector is safe for this GPU, the SATA 6 pin connector or the other one that connects straight to the powe supply?
Please I need assistance im planning to buy next week..
Definitely not SATA. It will say PCI-E and it will have 6 holes in it. Like this one:
You are going to use that one. Which power supply do you have?
