Geforce 210 low clock
Patchett
15
My nvidia geforce 210 1gb ddr3 card (yeah not the best and NO i dont want to upgrade) specs say graphics clock of 589mhz, processor clock of 1402mhz and memory clock of 1000mhz. But when i go into MSI afterburner or EVGA Precision its only at 135mhz core, 270 shader, and 135 memory idle. When playing a game it jumps up to a max of 405 core, 810 shader and 324 memory. World of tanks and similar games are unplayable, and trying to overclock using one of the two tools mentioned does nothing after hitting apply, it refuses to go higher (which is still below stock speeds). I am using the latest card drivers (331.58). Basically i want to know why its being throttled, and how i can fix it and maybe overclock. Temps for GPU at idle are about 45 degree's C, Full load no more then 55 C. Also is it possible to unlock voltages with this card in MSI afterburner or EVGA Precision? I have the Unlock Voltage control and monitoring check in options but its still locked, is this only for certain cards?
Thanks in advance.
Specs:
System Information
Time of this report: 10/28/2013, 18:18:10
Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.130104-1437)
Language: English (Regional Setting: English)
System Manufacturer: Compaq-Presario
System Model: GN578AA-ABA SR5233WM
BIOS: BIOS Date: 08/10/07 13:50:06 Ver: 08.00.13
Processor: Intel(R) Core(TM)2 Duo CPU E4400 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 2046MB RAM
Page File: 1363MB used, 2991MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
DxDiag Version: 7.00.6002.18107 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 210
Manufacturer: NVIDIA
Chip type: GeForce 210
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0A65&SUBSYS_082E196E&REV_A2
Display Memory: 1745 MB
Dedicated Memory: 978 MB
Shared Memory: 766 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor: HP w1907 Wide LCD Monitor
Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
Driver Version: 9.18.0013.3158 (English)
DDI Version: 10.1
BGRA Supported: Yes
Driver Attributes: Final Retail
Driver Date/Size: 10/15/2013 20:41:34, 15244272 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
Device Identifier: {D7B71E3E-4925-11CF-8876-23281FC2C435}
Vendor ID: 0x10DE
Device ID: 0x0A65
SubSys ID: 0x082E196E
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Its downclocking to safe on power, you don't need 3d clocks for most desktop usage, when you play a game or use anything the needs video power, it will jump its clocks back up. this is normal, nothing at all wrong with your card bro.
Also that card, no you can't unlock voltages on that particular card, 55C is well with in its safe zone for temps, I'd start to worry if its hits 85C+
Hello and thanks for the reply, But as i said the clocks aren't hitting what the stock clock is, even when playing a game such as world of tanks. The GPU usage is hitting 100% but the graphics card clock wont go higher (like 100mhz below stock clock) and it wont let me overclock it. My frame rate is terrible.
Thanks for the suggestion and link, fortunately after a reboot with the "apply overclock at start up" option selected seems to have fixed it, the graphics card now speeds up to stock clock and allows me to overclock it.
