The coolermaster that blue had 6 rails. The problem is, not only is having 6 rails bad (apparently mad power fluctuation), but i have NO idea which connector is on which rail, since they are not labeled. Its possible that i overloaded one rail with too many connectors, but i will never know.
The corsair has two rails.. all SATA/Molex connectors are on 12V2, plus two of the 8x molex -> PCI-E connectors are on 12V2, leaving the other 2x 8 molex -> PCI-E connectors, and i THINK the two hard wired PCI-E connectors (which i am currently using to power my 280) on 12V1.
If this is so, 12V2 is powering all 6 drives (4x hdd 2x dvd) + case fans and fan control, spread across 4 cables, and 12V1 is powering the graphics card.
I cannot think of a better way to set this up, so if THIS fails as well, the PCs next stop is the ground 30 feet below my window.
