geforce 4 temps.
G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
I have a geforce 4 ti 4200 64MB in my system running at a temp of 40.8C is
this standard, running 20MHz up on both GPU and Mem speeds gives 45.7C.
is this the normal temps or should I buy another cooler or a better graphics
card. in my current 8KRA2+, XP3200+ system when cold I can do a
3dmark2001SE of 12100 (300/600) but when warmed up I'm stuck with near stock
clock settings.
Robin
augustus
740
"robin.gordon1" <robin.gordon1@ntlworld.com> wrote in message
news:%ovrc.164$FT6.137@newsfe5-gui.server.ntli.net...
graphics
stock
> clock settings.
> Robin
That's not a temp to be concerned about. And unless you really need DX9, I
would not be rushing out to upgrade the card. You're running it as a Ti4600
or so. 12,000 on 3DMark01 is decent. Probably will do about 2700 or so on
3DMark03 at that o/c. Your score is exactly what my Radeon 8500 128Mb
running 300/600 on a Barton 3200 gets.
