GeForce 4 Ti 4600 running a bit slow...Help!!
Acid_Core
I recently bought a Leadtek WinFast GeForce Ti 4600 and I am using v41.09 of Nvidia's Drivers...My current specs:
Asus M/B (A7V333)
AMD XP 1700
256MB DDR
(I Guess that is all that matters...)
I have all the card's settings set to default and I have have anti-aliasing switched off as well as Anisoptric Filtering. But when I run Medal Of Honor - Spearhead (With all the settings maxed out...) i get an FPS of about 20-30...although it uses the Quake III engine...and from hardware guides that I have read on Tom's Hardware Guide I should be nearly getting 200 FPS...so if someone out there know what is wrong please tell me...O yes and when I run UT 2003 will all the settings maxed out it runs flawlessly with about 70 FPS but that is with 4x Anti-Aliasing and 2x Anisoptric Filtering...
Thanks in Advance
zero9ine
23
maybe the game is more CPU intensive than Graphics intensive or vice versa as opposed to the other games you mentioned...
I read that in one of the guides about the video cards.
-- 09
