Messing around with pieces from an old computer. Motherboard supports both cards (supports pci, and agp8x).
specs of comp(nothing spectacular lol):
2.4 ghertz p4
1gig ddr ram
windows xp home
Trying to pick which card would be best. Normally i'd think a 256 mb card would be better than a 128mb card, but the 256mb card is standard PCI. computer will mostly be used by my younger brother to play World of Warcraft together online when/if we both find the time. Buying another video card isnt really needed in this case, i know these cards are dated in comparison to new ones, but the computer will not be used all that much.
GeForce 6200 PCI (NV44) without TurboCache, 256mb. Some info can be found here.
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6200_PCI_.28NV44.29_without_TurboCache
vs.
Geforce 5200 FX AGP 128mb. Some info can be found here.
http://en.wikipedia.org/wiki/Geforce_5_Series
I was also wondering if there would be any downside of having both installed and running at the same time(to switch between the two, or possible dual monitor) ? I've read briefly about this, and it seems possible. Curious if anyone has advice or suggestions about it.
thanks for your time, if there's any confusion about the questions feel free to ask, and i'll try to clarify.
2.4 ghertz p4
1gig ddr ram
windows xp home
vs.
