Geforce 8400 GS Fan speed and Power consumption ?
varunmehta11
50
Is there any software which can display the Power Consumption and Fan speed of my XFX Geforce 8400 GS Graphic card ?
I have Vista 32bit OS.
emp
2,593
The power consumption on that card is so low that it doesn't really matter. The only way you can consume less power is with integrated graphics, you shouldn't really worry about fan speed either, since the card doesn't generate nearly enough heat to warrant any concern, but in case you want to, there's rivatuner.
Geforce8400victim
Actually, Rivatuner will not avail you much, because the Geforce 8400 GS does not have the connections which allow for fan speed control. This is a problem, because the card DOES in fact have overheating problems on account of its poor fan system. The fan won't spin, or spin fast enough, unless the card is excessively hot. In other words, the cooling systems for this card were just designed poorly.
Rivatuner isn't the only program that won't help you. There is no way to control your fan speed on this card short of somehow installing the hardware. I speculate that the best thing you can do is install a new fan and/or look into fan lubrication.
