GeForce 8800GT weird noise
danvilnoiu
17
Hi all,
System configuration : i7 / Assus P6X58D and an Antec EA 750 W / Antec 183P
A friend gave me a Geforce 8800 GT but when I plugged it in there is a weird noise (very strong sharp noise) and I am reading on the forum that the noise is coming from the Power Supply - I really do not believe this because it is a 750 W or really ?! how much do I need to 8800 ?
I connected the 8-pin EPS 12V and not 4-pin ATX 12V should I go different, am I doing something wrong ?
Thanks,
Dan
6-pin & 8-pin Supplementary Power Connectors were used depending on make and model. Most were 6-pin.
The high-pitched squeal is usually the result of the manufacturer using cheap non-shielded chokes and capacitors.
What is the amperage rating of the 12 Volt rail(s) of your power supply?
The ones with the little piezo speaker that sounds like a police or ambulance siren when you forgot to plug in the supplementary power connector.
