Geforce 9600 Gso Monitor issues
mayney93
6
emm how do i put this, bought a factory built pc a while ago well in feb 2009, and at first i fobbed it off as it only affected a few games and I said it was my monitor in my mind, then I tried it on 2 other monitors , the problem of the monitor shutting off and the only way to return to normal is to force a reboot, i knew it wasn't my monitor then so took it to a friend who is tech savvy, he said to back up the data and install win xp in case of it being a corrupt OS however when i was moving it i found it only has a 250 watt power supply unit and nvidia says the 9600 requires a 400 watt minimum so what's the cause ? OS or Psu please tell me Psu as i don't want to nuke the hard drive
mayney93
6
but thats how the computer came have they acidently but a psu in thats too weak, u absolutley sure its nothing else?
mayney93
6
so are you pretty damm sure that this is the cause coz im about to spend nearly 100 quid on a part to replace and thus fix it
http://www.ebuyer.com/product/134072/show_product_reviews#
what im gunna get if the psu is the cause
