Geforce 9800gt 512 replacement for Gateway FX4710
snap on guy
Best replacement for geforce 9800gt 512 in gateway fx4710. I'm using dual monitors. This machine worked great before being put into storage a year ago. Now the machine won't post with the video card installed, but boots just fine with the onboard video. I replaced the CMOS battery. I'm assuming that the graphics card has just gone bad. There is no setting in the BIOS to disable the onboard video.
What is the best replacement card for the money? I need a PCI Express card, with dual DVI output.
I'm not sure of anything honestly. The fan on the card spins, but I get an error beep instead of a post beep. It's like a bad memory beep. I'm thinking the memory in the card went bad. It is strange to me though that it was fine when I put it in storage, but it isn't now!
Anyway, thanks for the info on the card...... I'll check it out.
