Question GeForce GTX 1080
KingChangeIV
20
Hey guys and gals,
I have started to noticed when I am gaming I sometimes get garbage frames as in 20-30 when normally I am steady 60. I use Open Hardware Monitor and I notice when the frames bit the dust, my GPU has dropped significantly in temp it will usually run 80C but it can drop to 74c or around that number. What does this mean? I am trying to make this last as the shortage for GPUs is still ongoing and I want to know what the issue might be and how to resolve. Please share your thoughts! Thank you in advance.
Thermaltake Core V71 Extreme Full Tower Chassis
MSI PRO Z490-A PRO LGA 1200 Intel Z490 (MOBO)
Intel Core i7-10700K Comet Lake 8-Core 3.8 GHz (CPU)
EVGA GeForce GTX 1080 FTW DT GAMING ACX 3.0, 8GB GDDR5X (GPU)
EVGA SuperNOVA 1000 G2 120-G2-1000-XR 80+ GOLD (PSU)
CORSAIR Dominator Platinum RGB 32GB (2 x 16GB) DDR4 3200 (PC4 25600) Desktop Memory Model CMT32GX4M2C3200C16 (RAM)
NZXT Kraken X73 360mm (Cooler)
SAMSUNG 970 EVO Plus SSD 2TB - M.2 NVMe Interface Internal Solid State Drive with V-NAND Technology (MZ-V7S2T0B/AM) (Storage)
SAMSUNG 970 EVO PLUS M.2 2280 500GB (Storage) (OS)
Extra's
NZXT AC-HUEPS-M1, HUE+ Smart RGB Color Changing Digitally Controlled LED PC Lighting
BenQ GW2765HT 27-Inch 2560x1440 IPS Monitor, 4ms Main Monitor
Acer S271HL Dbid 27" Secondary
Extremely high background CPU usage. You need to close everything else beside the benchmark and run it again.
I don't see anything else that is too important from that though.
Try DDU in safe mode to remove and reinstall your GPU drivers.
