C Chinatsu Reputable Jul 9, 2014 2 0 4,510 Jul 9, 2014 #1 I wanna buy vga card n i confuse to this 2: Geforce gtx 560 1gb 256bit vs GTX 650 Ti BOOST 2gb 192bit Which one is the best? Thanks
Solution geofelt Jul 9, 2014 The GTX 650 Ti BOOST is a more modern and stronger card. It also needs less power. 450w should do it. A GTX560 would need about 520w.
TryHardVermin Honorable Sep 22, 2013 240 0 10,710 Jul 9, 2014 #3 The gtx 650 ti is better. The more VRAM is always better. Upvote 0 Downvote
delellod123 Honorable Jun 5, 2012 1,094 1 11,660 Jul 9, 2014 #4 Go for the 650 ti. A pretty good card. The 2 GB will be beneficial. otherwise here is benchmark Upvote 0 Downvote
delellod123 Honorable Jun 5, 2012 1,094 1 11,660 Jul 9, 2014 #5 http://tpucdn.com/reviews/ASUS/GeForce_GTX_650_Ti_Direct_Cu_II/images/perfrel.gif Upvote 0 Downvote
geofelt Titan Oct 9, 2006 54,291 4,145 174,240 Jul 9, 2014 Solution #6 The GTX 650 Ti BOOST is a more modern and stronger card. It also needs less power. 450w should do it. A GTX560 would need about 520w. Upvote 0 Downvote Solution
