Greetings guys.
I've been trying to solve this issue but to no avail. And makes worse that I'm no expert and have no idea what I'm doing.
To the problem at hand: I have a geforce gtx 660 card and I wanted to use a 2nd monitor. So I bought a http://www.lg.com/uk/monitors/lg-22M38A . The one I was using before was a http://www.lg.com/ca_en/monitors/lg-L192WS-lcd-monitor.
Now this is the back of my graphic card: http://www.extremetech.com/wp-content/uploads/2012/09/geforce-gtx-660-bracket_gallery_preview.png
The old monitor came with a dvi-i adapter (24+5 pins) which I'm using for the bottom entry of the card. To connect the second monitor I had to get a simple dvi-d adapter with 24+1 pins (http://s474818768.onlinehome.us/list/dvivga/011.jpg). However this does not work. My 2nd monitor is simply not detected (nothing shows on windows/NVIDIA panel, the monitor keeps giving me the "check signal cable" message).
What is the issue? Am I doing the connections wrong, are the monitors incompatible, is it the wrong adapter?
Any help would be appreciated.
PS: I suppose I cannot connect both monitors on the bottom row of plugs (using a dvi-to-vga for one and hdmi-to-vga for the other, for example)?
