GeForce GTX 750 Graphics Card Have Graphics Issues
Owzzy
So I recently bought a new Geforce GTX 750. I plugged it all in and connected it to my tv/monitor using a vga cable and a vga adapter. It worked perfectly fine as it should. So then I replaced the vga with a hdmi, and a lot of things started becoming squewiff. The resolution was set to max (as recommended) and the top and sides were off of the screen and the screen seemed really blurry compared to when I used the vga. This is annoying because I would like to run 2 screen at once (both with good quality). Anyway... Thanks in advance.
PC Specs:
Gigabyte Z68AP-D3 Motherboard
500watt PSU
Gigabyte GeForce 750 1024mb GDDR5
8gb Ram
UPDATE: I should also note that I cannot play most of my Steam games because whenever I start the game up, it just gets stuck on a black screen. I think this might be something to do with previous game settings.
Have you tried uninstalling the previous drivers and installing the new driver for this GPU? Sometimes, that is the cause of your problem. Doesn't matter if their the same GPU maker. You gotta uninstall the previous drivers and reinstall them.
