GeForce GTX 760 (2 way SLI) OR GeForce GTX 770?
TeamSignal
48
Im currently upgrading my PC and im still stuck between having sli GTX 760s or a single GTX 770. So i would like to know what you think.
PC Specs
CPU - Intel i5 3570k
Motherboard - ASRock Z77 Extreme4 ATX LGA1155
RAM - 16GB 1600mhz
GPU - MSI GeForce GTX 760 (2 way SLI) OR GeForce GTX 770
PSU - XFX P1850SNLB9
Monitors - 2x LG IPS234 23" running at 1080p
Ill use the computer for extreme gaming, recording and video editing/rendering.
What's your PSU? Two 760s would need at least a 550W PSU, but preferably 600-650W to keep it cool (and quiet).
Also two 760s are far better value than a single 770 if you don't mind the higher absolute price. It gives you more performance than a GTX Titan and will certainly last you a long time. However, I might go with 4GB cards because that way the VRAM wont bottleneck your awesome SLI speed a few years don't the line, especially if you add a third monitor.
2GB would be fine for a single GTX 770 since the memory wont in all likelihood be a bottleneck for a single card, but two 760s in SLI are going to outlast a single 770 by quite a fair margin.
Im getting a 850watt psu, and can you link me to a suitable 760?
Fair enough, but you wont really need more than 700W.
For 4GB 760s you could get either of these:
http://www.amazon.com/EVGA-GeForce-GTX760-Dual-Link-04G-P4-3768-KR/dp/B00E0N49C8/ref=sr_1_1?s=pc&ie=UTF8&qid=1375638151&sr=1-1&keywords=gtx+760
http://www.amazon.com/Gigabyte-GTX760-GDDR5-4GB-Graphics-GV-N760OC-4GD/dp/B00EAMQMUG/ref=sr_1_8?s=pc&ie=UTF8&qid=1375638151&sr=1-8&keywords=gtx+760
Both are 60-70 USD more expensive than a 2GB model, but if you go SLI it's worth it. There's also an Asus 4GB model which would have a superior cooler, but its availability seems to be poor, at least on Amazon.
Hows this look then?
http://uk.pcpartpicker.com/p/1o9ra
Looks good to me.
However, I would reconsider that 16GB RAM you have planned, unless you already have it. If your main use is gaming and you don't do professional level Photoshopping, video editing or some such, then you wont benefit from more than 8GB of RAM.
So for a gaming rig get 8GB of RAM and use the money you save to either get yourself an SSD or up the RAM frequency to 2133 MHz. (SSD being the far better choice of the two, being a very clearly noticeable improvement.)
