Hi guys,
Just wanna play some BF V on lowest settings, but PC is lacking.
I5-4670L
GTX 760 2 GB
B85-G41 PC Mate
8 GB Ram
I've seen people do it, mine just can't for some reason. Did all sorts of tests like Heaven and FurMark. Heaven had low FPS (12-15) but low temperature (68 degrees), FurMark had enough fps but high temperature ( 87). CPU seems to be having trouble as well during the games (being at 100%).
Just ordered a good fan to overclock CPU with Extreme Tuning. I know it should be time for an upgrade, but I don't replace things usually unless they're broken. Unfortunately, this motherboard doesn't support SLI, so another cheap 760 is a no go. Tried the MSI afterburner, but didn't work either.
Any other suggestions?
I5-4670L
GTX 760 2 GB
B85-G41 PC Mate
8 GB Ram
