So I have a HP Pavillion P6000 computer model with 5 gigs of RAM, 650 GIGS hard drive space, a 700 watt power supply. I just bought a Geforce GTX 770 graphics card, and when I plug it in, turn the power on, the power supply light flashes for a slight second, then nothing happens, no power at all.
On the instructions it says I need a minimum of 600 watts or greater system power supply with one 6-pin and one 8-pin PCI express supplementary power connector for each graphics card,
and compatible with PCI express or up to PCI express 3.0 compliant motherboard with one dual-width x16 graphics card.
I plug all the necessary pins into the card and make sure the card is snugly in.
So my question is, why won't it turn on with the card inside? Is my power insufficient? Is it incompatible with my motherboard, might I have it plugged in wrong?? What's the deal?
