Geforce Gtx 960 2gb running dual monitors
Keith Miller
Commendable
Jul 25, 2016
5
Hi i'm currently running my computer with one monitor using dvi cable, and i was wondering cause i wanted to add another monitor, how do i connect the second monitor to the graphics card? since the graphics card only has one dvi port
You use one of the HDMI or Displayport ports. Obviously you would need to use a monitor that has a HDMI port or Displayport, or use some kind of adaptor.
The monitor will have both dvi and vga. And the 960 only has do and hdmi.
