Geforce GTX 970 Fan Size, 2 Fans not working
Oct 23, 2018
I have had 2 of my fans not working for a while would like to buy 2 new fans and replace the once i have but i can not figure out how big they are to find the proper fans to replace them, anyone have any ideas? I stream on my computer and i cant have my GPU go out because of heat, i watch it constantly and it never goes above 80 Celsius.
Replacing fans on a graphics card is not as simple as replacing case fans. I'd recommend getting a new aftermarket cooler for your model.
All be said, I've never had to deal with this problem, so you might want to wait for someone else to reply.
i would like to just replace the fan's, i can see that they are easy to replace i just need the actual size of them i can take it out and take a pic of them so you can see if needed.
Edit: i have Pictures but i cant post them here.
If you can't post them here, you can also upload them on another site like Imgur, then give us the link.
If you are intent on replacing the fans, you can probably find replacement for your specific card on places like eBay. However, please do make sure you're buying what you're looking for. Also, I don't think the size will matter, since you should probably try to get a set of fans identical to what you have at the moment.
