Hello! I posted on this forum maybe 8 years ago seeking help on building my first tower. It sort of died yesterday.
I have been accumulating various components over the past several years, originally hoping to build a new tower in a couple months. My current tower dying has sort of forced my hand. I'm hoping you all will be able to help me again on making a true beast of a machine.
I tried to follow the guidelines in the PC Build Advice sticky. Thanks for your help!
Approximate Purchase Date: Immediate
Budget Range: ~$6000 (including monitors and excluding pre-purchased parts)
System Usage from Most to Least Important: Gaming, 3D modeling, data modeling, etc
Are you buying a monitor: Yes (3)
Do you need to buy OS: Yes (Windows 10 Pro)
Preferred Website(s) for Parts: Amazon, Newegg, other
Parts Preferences: No preference. Currently eyeing the AMD Threadripper processors and already have an EVGA 3090, along with other parts.
Overclocking: Yes / Maybe
SLI or Crossfire: No
Your Monitor Resolution: 2560 x 1440 or 3840 x 2160 on three monitors
Additional Comments: Software used: Meshmixer, Blender, Minitab, JMP, various 3D printing related softwares, AutoCAD software, Photoshop software, various games.
And Most Importantly, Why Are You Upgrading: Ran into some software/OS upgrades on my current tower that bricked it. Considering it is ~7 years old at this point, I think it's time. I need something to last me another 6-8 years that can handle some heavier computational work and heavy gaming.
I have a couple of specific questions/topics that I'm hoping you all can help me with.
- I want to fill up all of the RAM slots on the motherboard (8). I already have 4 sticks of Corsair Dominator Platinum RGB DDR4-3466 CL16 Memory. Should I grab an additional 4 sticks of this or opt for an entirely different RAM? It is slightly older memory, but reviews still say it is decent. The goal is a minimum of 64gb of RAM.
- I am lost on cases. I may eventually create a custom cooling loop, but that's not a priority right now because I am currently tower-less. I want to make sure the 3090 will fit, and that there is enough room for adding a custom water loop at some point. In the meantime I will be opting for a standard Corsair/Kraken CPU water cooling system. I did not include it in the pcpartpicker list because I am unsure about fan/radiator sizes. I do not need a case that allows for a computer-within-a-computer. That's a bit too much room and will not fit where the tower needs to go...
- I have been gaming on 1440p and have had my current monitors for ~7 years now. Shifting to 4k has me anxious. I haven't kept up much on different monitor companies, so I took a stab at both 1440p and 4k monitors below. Is 4k on 27" monitors worth it/noticeable? I remember the shift from 1080 to 1440 being very nice, but I would probably be content with consistent, blazing performance on 1440p monitors.
- I'm not sure how overkill to go on power supply. Keeping in line with the mindset of future-proofing, I'm leaning between a 1200 and a 1600 watt in case piece-meal upgrades are needed along the way. Does anyone have any positions for/against either? Is a 1600 watt really necessary?
- Any other wisdom or things I should think about?
This is about what I have so far:
All items with a price of $0 are items that I already have (graphics card, storage, some RAM). As mentioned above, I'm willing to buy new RAM, as I think 32 more gigs of my current RAM costs as much as 64 gigs of a newer RAM...
PCPartPicker Part List: [url=https://pcpartpicker.com/list/24DCbh]https://pcpartpicker.com/list/24DCbh
CPU: AMD Threadripper 3970X 3.7 GHz 32-Core Processor ($1971.29 @ Amazon)
Motherboard: Asus ROG ZENITH II EXTREME ALPHA EATX sTRX4 Motherboard ($819.99 @ Amazon)
Memory: Corsair Dominator Platinum RGB 32 GB (2 x 16 GB) DDR4-3466 CL16 Memory ($0.00)
Memory: Corsair Dominator Platinum RGB 32 GB (2 x 16 GB) DDR4-3466 CL16 Memory ($262.52 @ Amazon)
Storage: Samsung 860 Evo 4 TB 2.5" Solid State Drive ($0.00) (for work)
Storage: Samsung 860 Evo 4 TB 2.5" Solid State Drive ($0.00) (for play)
Storage: Seagate EXOS Enterprise 14 TB 3.5" 7200RPM Internal Hard Drive ($0.00) (for storage)
Video Card: EVGA GeForce RTX 3090 24 GB FTW3 ULTRA GAMING Video Card ($0.00)
Sound Card: Asus Essence STX II 24-bit 192 kHz Sound Card ($299.99 @ Amazon)
EITHER
Monitor: LG 27GL850-B 27.0" 2560x1440 144 Hz Monitor ($496.99 @ B&H)
OR
Monitor: LG 27GN950-B 27.0" 3840x2160 144 Hz Monitor ($796.99 @ B&H)
Total: $7498.25
Generated by PCPartPicker 2020-10-27 18:39 EDT-0400
EITHER
OR
Total: $7498.25
