General System Feedback and watercooling advice!
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hello All! :)
I am once again calling on the expertise of the tomshardware community. I would very much appreciate it if people could take a look at this custom build and put together a custom water cooling loop for £300-£400 cooling both the Graphics card and the CPU.
http://uk.pcpartpicker.com/user/henry07th/saved/fmNxFT
Please leave any form of feedback whether it is what i asked for or just general feedback. Though if you suggest i do not buy something i have already bought then you are of course to late.
If you are going to plan the watercooling for me (Which would be greatly appreciated) then please use one of the following sites:
-http://www.overclockers.co.uk/
-http://www.watercoolinguk.co.uk/
Thanks very much
in advanced, and if you are a member of pcpartpicker then feel free to one up my project to get it kickstarted in the partpicker community.
Also feel free to move this thread somewhere else if you think it will get more responses.
Once Again, Thank You Very Much In Advance!
id go with a i7 4790k and a Asus MAXIMUS VII HERO because the z97 chipset should support the next haswell cpu's so u wont have to upgrade your mobo when you upgrade your cpu. The rest of the pc is amazing though. I haven't ever done watercooling so I dont feel right recommending anything. Just so you know the 780 ti is amazing and worth every penny. I have one myself and its great.
