Hey guys, I need some serious help with my laptop. It's a HP Beats Special Edition 15-p010nm. Specifications are as follows:
CPU: AMD® Richland APU Quad Core Processor A8-5545M clocked at 1.7GHz, Turbo up to 2.7GHz I believe
GPU: AMD Radeon HD8510G Integrated graphics processor
RAM: 8GB, 7.19GB is reported as usable
OS: Windows 10 64bit, legit copy obtained via MS' upgrade program back when it was active, originally it ran Windows 8.1 64bit
Screen resolution is 1920x1080
Now, here's my problem: It's unbearably slow! Firefox and Chrome lag like hell, YouTube freezes a lot, Facebook as well, and the OS takes a pretty long time to start. Also I have really low FPS in literally every game, including those flash games on the internet. Not newer games, mind you, I was trying to play TES 3: Morrowind and it ran pretty bad, as well as Oblivion, Fallout 3 and New Vegas, Unturned, Minecraft, DiRT Showdown, Counter-Strike: Global Offensive, the original Counter-Strike, GTA:SA , Starbound et cetera, most of which can run on potatoes, and I am aware of the fact that my laptop is REALLY underpowered, but some of these run ridiculously bad for what they are. I was also experiencing some sudden shutdowns.
My first suspicion was thermal throttling, so I brought the laptop to the shop, and told them about the issue. They fixed it a couple of weeks later, and they told me that they had to replace the thermal module, which was faulty. The laptop stopped shutting down at random, but the performance was still pretty bad. In the meantime, I had upgraded from Windows 8.1 to 10 legitimately, still no difference, and I had also tried several Linux distros, namely Mint, Ubuntu and Fedora, which ran exactly the same, if not worse than Windows. I had wiped the HDD several times, and I never really pirated any games, as all my software is either purchased or free, so I really don't have viruses on my system. Bloatware that came with the unit is also out of the question, because I did fresh OS installs several times.
I did run HWMonitor to check the lap's temperature:
http://prntscr.com/ek0ccj
I'm not a hardware expert, but I think 100+ degrees is a bit too much for a CPU, especially on a laptop. Could it be the dust accumulation inside of the vents? I honestly doubt that such temperatures are normal, but I could be wrong.
Now if someone with knowledge about this could help me out and give me an advice or two on how to fix this, I'd greatly appreciate it! Thanks in advance!
P.S. I apologize for any grammar mistakes I most likely made, English is not my first language.
