[SOLVED] Generic Case Compatibility With Motherboard
VERSION_1583
Commendable
May 7, 2021
98
4
1,545
Hi,
I would like to ask if an DQ67SW Intel Motherboard would be compatible for a Lenovo ThinkCentre E73 case?
The motherboard that comes with the case is a Micro ATX and so is the DQ67SW.
However, my concern is whether the studs/stands will be enough or compatible to hold the motherboard in place securely without causing problem or short circuit.
The case studs can be observed in this video: (2:00)
View: https://youtu.be/lIAK_qqxh6E
Thank You.
Mount stud hole placement is standard on all motherboards so it should fit.
Thank You :)
I just got home and opened my case. The screws appear to matches the Intel Motherboard.
The video that I just shared made it seems like you don't need to screw it in. Which made me nervous since I already ordered the motherboard lol.
A side question, is it alright to clean the case using wet wipes and leaving it there for a day to dry?
