Generic Non-PnP monitor issue
Mios
Im having Acer TV which im using as a monitor by VGA cable running at 1440x900 and at 75hz. I turned on pc today and while i was looking for something i noticed that the screen isnt fluent as it should be. When i got into display properties it says that is Generic Non-PnP monitor but it was Generic PnP monitor. Screen refresh rate was set to 60hz and i couldnt change it back to 75hz but my resolution is still unchanged so resolution is okay but refresh rate isnt. I also got into properties and it says
Device type: Monitors
Manufacturer: (Standard monitor types)
But previously it was displaying all the infos normally.
Then i tried in Radeon driver to see what is happening. Everything was displayed as Not supported
https://prntscr.com/j5yng6
I was actually messing with drivers like a week ago because i have had a problem with crimson drivers which cant update to newer crimson driver and its displaying some error so i installed old catalyst driver and then uninstall crimson.
Graphics card: AMD(Gigabyte)Radeon HD 6570
Current driver: Catalyst 15.7.1
Thanks for help :)
Radeon HD 6000 Series Graphics products have been moved to a legacy support model and no additional driver releases are planned.
For users looking for a WHQL certified driver, the AMD Catalyst 15.7.1 driver will continue to be available for users running Windows 10, Windows 8.1, and Windows 7.
Beta driver
Radeon Software Crimson Edition Beta 260 MB Crimson Edition 16.2.1 Beta 3/1/2016
