generic power supply?
saarxee
252
i have "ABPower" power supply, this is generic or not?
my system:
I3 2100
1X4GB RAM
GT430.
recommended me to purchase "Seasonic" S12II 430W power supply?
my system Can be burned because the current power supply? it's dangerous?
Generic PSU's will work fine but are not very reliable when it comes to high power use. The majority of people reccomend quality name brand PSU's the have a 80 plus rating. As stated above when generic PSU's fail they normally cause damage to other parts also.
Then upgrade your PSU, you should be able to get a quality PSU for under $50. And for a GPU go with a 7790, 7850 2gb, 650 Ti boost all can be found for under $150.
Good PSU? YES! Will not run the GTX 670 you will need more watts to run that. For the 670 I would go with a 600w or better PSU. Remember you want a balance, your current CPU would bottleneck with the GTX 670.
