Get a 4k monitor with a 1080p graphics card
starwars245p
90
I have a gtx 1060 6gb graphics card and at the moment have a 1080p monitor but i was wondering if i replace my monitor with a 4k monitor will make any difference or make the quality worst, being that the graphics card is 1080p
Graphics cards don't have an inherent resolution.
A 4K monitor will look better but your framerates in games will be less.
With that graphics card, I would not recommend getting a 4K monitor.
If you intend to play games, you will have to lower the settings significantly to get good FPS. As far as I know, even a 1080 is only just about well equipped enough to run 4K decently on demanding games. (If that).
I would recommend looking at 1440p monitor instead.
But yes! You can get a 4K monitor and it will function.
Agreed. The 1060 plays nice with 1080p. A 4K monitor would necessitate at least a 1080 for 30FPS 4K gaming with some changes to in-game settings. The 1440p monitor would be okay with the 1060.
Technically speaking it will make the experience worse at your current settings because a 4K monitor just has too much real estate for the 1060.
The monitor dictates the resolution and not the card.
Why do you want to upgrade to a 4K monitor? Is there a budget or do you already own one?
If you do have a budget you might offer your complete specs.. Your can copy and paste https://www.piriform.com/speccy's summary page here. Or click on that Polaroid icon above the text box and paste a pic based url such as example. jpg or example.png. We might see a better place for your to invest your money in. Click icon, paste url, click ok and that would result in an embedded pic like
