J josephcrone35 Jan 28, 2019 1 0 10 Jan 28, 2019 #1 how to connect rca rts7010b soundbar to 55 inch lg 50ln5100-ub
Phillip Corcoran Titan Moderator Sep 7, 2013 26,108 913 120,140 Jan 29, 2019 #2 Both devices should have an optical audio port according to their respective specs sheets --- so buy an optical audio (Toslink) cable and connect them together with that. Cable like this: https://www.amazon.co.uk/AmazonBasics-Digital-Optical-Audio-Toslink-Black/dp/B00L3KO5WK/ref=sr_1_2_sspa?ie=UTF8&qid=1548771685&sr=8-2-spons&keywords=audio+to+optical+cable&psc=1 From the picture of the optical cable above, you should easily be able to identify the location of the optical ports on TV and sound bar, or check the user manual for each device. Upvote 0 Downvote
