hatemf90 :
Thanks, would the pcie card have an advantage for quality of sound or is it just extended range? and also if i go with a regular usb any particular brand I should with?
The pcie card would theoretically allow better signal/range but is dependant on the environment as well. You can also move the external antennas a bit to find a better singal.It also comes with wifi. With certain pcie wifi+BT adapters, you can upgrade the wifi/BT module itself or replace one if it is faulty. But it has a higher cost than a usb bluetooth adapter due to the added features.
With the brands, there are only a few manufacturers that create the wifi/BT modules. You may find a particular type is better for you or they may be similar. I currently have a...
