[SOLVED] Getting around 90mbps on ethernet when link speed is 1gbps, over 300mbps on wifi
thataccsetuper
Commendable
Oct 5, 2017
8
I'm having a problem of getting around 90mbps on ethernet but over 300mbps over wifi on the same device. I'm using a Thinkpad Yoga S1 with a OneLink Pro Dock, with the ethernet being connected to the dock. I have tried using 2 other cat5e cables and another dock but still the same problem. I check the link speed and it is always at 1gbps. I used to get over 600mbps with the same setup and 2 other cat5e cables and suddenly had this problem.
ethernet speedtest: https://www.speedtest.net/result/c/e675723b-3785-4c95-adb0-524c0391d68d
wifi speedtest: https://www.speedtest.net/result/c/16411e17-e9b9-4c65-b35e-e2d8f077ebb8
