I want to get Dolby Digital 5.1 and/or Dolby Digital Plus (either spdif optical or coax) from Windows Media Center via an external USB sound card. I've already used HDMI from the same system and it has DD output, so I know it's available in the PC, somewhere.
The unit I bought is only outputting 2 channel PCM. In the Control Panel, Sound, Speaker Properties, there is no option for AC3 or E-AC3; only three 16 bit options (FM quality, CD quality, DVD quality) which I tried; the configuration only 'sees' 2 speakers.
I also tried using a 'Windows 7 Codec Pack' from CNET.com that says it has DD & DD+. When I installed it and set it up, it would not save the settings that select AC3, etc.
The chip used on the USB card is a PCM2704. All I can figure is that it's only capable of PCM, but I've been told that any USB card with SPDIF out should be able to pass DD from a source that has it, like live HDTV from Windows Media Center. In other words, no encoding is necessary by the card.
Here's a link from ebay to the product: http://www.ebay.com/itm/PCM2704-USB-to-DAC-Optical-S-PDIF-USB-Sound-Card-Decoder-Board-Aluminum-case-/262001131967?hash=item3d007c01bf
Help.
Help.
