I ended up using DP. Have no issues with setting colour to 10 bit and 240hz. Picture looks great.You should definitely use HDMI with that monitor as Display Port 1.4 doesn't have enough bandwidth to operate the display without DSC.
I didn't say it wouldn't run just that it'll use DSC which can have its own set of problems which you can read about here: https://tftcentral.co.uk/articles/loads-of-displayport-2-1-testing-and-updatesI ended up using DP. Have no issues with setting colour to 10 bit and 240hz. Picture looks great.
I'll try HDMI 2.1 when I go on next timeI didn't say it wouldn't run just that it'll use DSC which can have its own set of problems which you can read about here: https://tftcentral.co.uk/articles/loads-of-displayport-2-1-testing-and-updates
I chose to avoid it on mine and would never suggest someone use a connection that requires DSC when there's an alternative.
The connector type doesn't really matter just whether or not the protocol features are supported and whether or not there is enough bandwidth.HDMI is technically better but I use DP simply because I cant notice any differences and I use HDMI for my TV connect.
Thanks. I noticed the alt+tab screen blanking out. I'll try HDMI 2.1. and report back. ThanksAs TheStryker said, HDMI is slightly better in this case because you can get 240hz / 10 bit color with DSC switched off in the OSD. You need to have DSC on to do this with the display port connection. DSC is supposed to compress the signal without any noticeable loss in visual fidelity. This may be true, but NVIDIA has had some long standing bugs related to DSC. They aren't deal breakers, but they are annoying. A long pause after alt tabbing out of fullscreen games is one that comes to mind. It's definitely ok to use DP with DSC, but your life might just be slightly easier with the HDMI connection.
Thanks dude. I changed to HDMI 2.1 and turned DSC off. It's nice when you alt tab out of Windows. No blank screens or anything. Thanks.You should definitely use HDMI with that monitor as Display Port 1.4 doesn't have enough bandwidth to operate the display without DSC.
