getting new PC and wondering if i will be able to overclock it without issue.
dylanmcc
8
planing on getting this PC. will everything be okay for overclocking or any other issues anyone see with the setup?
Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound
CyberPowerPC X-Nova Mid-Tower Gaming Case
CPU: AMD FX-8320 3.50 GHz
CS_FAN: Maximum 120MM Case Cooling Fans for your selected case
FAN: Cooler Master Seidon 120M Liquid Cooling CPU Cooler -Dual Standard 120MM Fans
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
MEMORY: 8GB (4GBx2) DDR3/2133MHz Dual Channel Memory (ADATA XPG V3)
MOTHERBOARD: GIGABYTE 990FXA-UD3 AMD 990 ATX w/ Ultra Durable 3, On/Off Charge,
POWERSUPPLY: 800 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
VIDEO: XFX Double D AMD Radeon R9 280 3GB
Nope, setup looks alright and you should be able to overclock well on that motherboard(8+2 Power phase, VRM heatsinks). I have it myself and overclocks just fine. If anything, I would change that power supply to one of known company like Seasonic, EVGA, Corsair, Antec etc.
You also don't 800W of a power supply. If you can, put an SSD in there. Put one in mine recently and everything is just faster (not gaming performance wise)
