Getting screen tearing with htpc. need help
saint1000
28
i have a dell gx620 tower with a radeon hd5550 video card running a sanyo dp50740 plasma tv. the only thing i use this for is streaming movies. i a, getting screen tearing bad in action movies and sporting events. doesnt matter if im streaming or playing a movie off the hard drive. im running windows xp. ive played for hours with ccc with no luck. any ideas?
saint1000
28
thats all i use it for is movies. i dont see or notice it on the desktop. it only happens in fast panning. ive tried powersrip, playing with the ccc and can not seem to get it to go away. i get it with netflix, flash videos, vlc media player. ive checked cpu useage and thats under 10% when its happening. the radeon 5550 card has a 1gig of onboard memory. i dont know what else to try
RussK1
Splendid
Force Vsync in catalyst control center...
RussK1
Splendid
If it makes you feel any better to offer consolation I don't think it's your hardware nor software... plasma T.V's usually have a really high refresh of 600hz (which is the main reason I'm a plasma guy) and I looked your particular T.V. up and it's confirmed to have a 600hz refresh rate.
I have a HTPC hooked up to my Panasonic Viera in my livingroom and I get tearing as well (esp. with Netflix). You could go into "desktop properties" in catalyst and play with the refresh settings... alternatively you could go into "display color" in catalyst and enable EDID. You may have a problem with Blu-ray though... for some reason when I had it enabled and I played Blu-ray I would get total color distortion, anyway it's worth a shot.
edit: enable triple buffering
RussK1
Splendid
First, what connection are you using?
I assume you only have the option of 1280x720 right? Go into Catalyst "HDTV Support (DIGITAL FLAT-PANEL)" and create a custom resolution to match the display's native res. ~ 1024x768.
saint1000
28
i will have to check edid when i get home. the plasma is mounted on a wall and there is a 50ft hdmi fished down the wall and up the oppisite wall where the pc is. i could try running another across the room for ttest purposes
RussK1
Splendid
While HDMI offers the highest video resolution currently possible it does have it's drawbacks; HDMI cable isn't suggested for long cable runs (50ft is beyond spec-compliant)... HDMI cable is manufactured out of twisted pairs of copper conductors that are small-gauge (instead of the usual coaxial cable) and this can cause signal integrity problems esp. considering your source output.
Try a shorter HDMI cable... and if the problems clear up you could look into a repeater.
I am glad you came along russwood :)
This one had me baffled
Only thing I can suggest is that I notice on my settings
that is has the option to force HD settings and also use some weird refresh
rates like 30HZ interlaced etc
I do know that the EDID somtimes is a faulty system
I get alot of false settings sometimes
and you can force HDTV settings
RussK1
Splendid
Yeah EDID is a toss-up... I know it doesn't' work with Blu-ray playback at all. I have my HTPC hooked up via DVI-to-HDMI... I get some tearing but it's barely noticeable. Usually happens when switching scenes in netflix... Don't happen when I play a dvd, so perhaps the problem lies in the bit-rate of the stream myself.
Edit: and the card in my livingroom machine is a 9500 GT so I know this problem isn't unique to ATI...
saint1000
28
i cant seem to find were to force hdtv option.the other thing i noticed is i dont get the tearing when watching videos on vudu.it seems netflix, hockey streams, and videos i have saved on my hd. i dont have a blu ray drive. could it be a flash problem?
RussK1
Splendid
I think it can be isolated to Netflix - play a DVD I bet the problem isn't there.
Go into Catalyst and open "video\video settings" and check all that apply to internet video~
