B bountythehunter Reputable Aug 18, 2014 38 0 4,530 Jan 28, 2015 #1 does that card work in this ? : AMD athlon(tm) II X2 250 Processorm, MMX, 3Dnow (2 CPUs), 3.0GHz 2016MB RAM
Solution dark_globe Jan 28, 2015 colour is irrelevant ... what is important is how it looks like : http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-the-PCI-Express/190/4
dark_globe Splendid Aug 16, 2013 1,373 229 26,590 Jan 28, 2015 #2 if your motherboard has pcie express x16 slot it will work ... but you won´t be able to play any recent games on such a weak configuration ... Upvote 0 Downvote
B bountythehunter Reputable Aug 18, 2014 38 0 4,530 Jan 28, 2015 #3 dark_globe : if your motherboard has pcie express x16 slot it will work ... but you won´t be able to play any recent games on such a weak configuration ... is it the blue one ? Upvote 0 Downvote
dark_globe Splendid Aug 16, 2013 1,373 229 26,590 Jan 28, 2015 Solution #4 colour is irrelevant ... what is important is how it looks like : http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-the-PCI-Express/190/4 Upvote 0 Downvote Solution
B bountythehunter Reputable Aug 18, 2014 38 0 4,530 Jan 28, 2015 #5 dark_globe : colour is irrelevant ... what is important is how it looks like : http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-the-PCI-Express/190/4 Thank you for the information Upvote 0 Downvote
