Ghosting and horizontal lines
Susan Willoughby
My monitor has a lot of ghosting and grey horizontal lines across it. What's causing this? Monitor about 4 years old - used for work - running Windows 7 OS.
How can I put it right?
Thanks for your speedy response!
Lots to answer here:
1. HP 2009v Series Wide LCD Monitor
2. 1600 x 900
3. don't think I use an adaptor - how would I know?
4. It has been doing this for some time but I just found this website
5. I have had the computer tower and monitor with peripherals for over 4 years - I don't do gaming.
6. I have a Canon MG8250 printer about six inches away from the tower and about 18 inches away from the monitor which is about six months old - I had the ghosting and horizontal lines long before I changed printers
7. I have very limited space on my desk - there is a multi-socket just behind my monitor with 5 sockets in use
8. I haven't moved either the Tower or Monitor since it was purchased in 2009 so I can't see how any cables could come loose.
9. I don't have another PC
10. I regularly check the resolution - just in case this will sort the problem.
11. I don't know whether its DVI or VGA - probably the latter - how do I find this out?
Thanks
