Ghosting blur badly on ViewSonic VX2252MH Need help
Colyn_
I tried everything i tried dvi ,hdmi,vga ghosting badly still in games and even when not in games and its not my rig. I got a gtx970ftw+ with a fx8350 and 16 gb ram before this montier i used a crappy crt 1600x1200 now i wasn't experiencing ghosting on the old montier but this one. I am and it cant be that famous lcd montiers are known for ghosting bs cuz i got a 50 inch tv and its 1080p 60 hz as well but response time is 8.5 ms and it doesn't have ghosting. I even went so far as using the hidden service menu on this montier to disable the od cuz apparently its a common fix along with burn in but they wont stay off they turn on immediately once i leave the menu. I tried contacting viewsonic no dice emails have gone unanswered for a month or two so shows how good brand they are my return/replacment period expired on amazon so can't do anything with that either. I am at a really fucked corner and i have no other possible idea what i could do i tried everything the ghosting is annoying anything i move its a ghosting blur.
I also have the response time set to ultra fast the ghosting is bad there standard option which is lowest it is like motion blur but not a ghost like blur but still is bad. Advanced is the middle but has both blur like a effect and little ghosting but i want smooth ghost free picture i also have this montier on 60 hz 1080p.Sorry for poor grammar and punctuation its not good i hope who ever answers i hope u got other solutions i could try. Hell view sonic has a faq on ghosting says it could be cross wire interference or low quality cables are they trying to say there cables that came with the dam montier are low quality along with amazon basic hdmi cables. I am not spending stupid money for expensive video cords i also tried to check if the wires are crossed or what not there not.one last thing I been googling a ton of times on this and i tried lots and lots of fixs idk what one i could possibly do that i haven't tried and btw i don't have another computer i could test this on i do got a dvr not the best to test it on but it doesn't have the ghosting blur so idk.
Well i do got like 3 mini display ports on my gpu but the montier doesn't support that and i don't have a cable for that nor do i got a converter to do that.Btw the hdmi cable i am using is 1.4 but i don't think a 2.0 would make that big of a difference same goes for regular dvi to dual link cuz my montier does support dvi/dual link but dual link is expensive. I would understand expensive cables maybe needed if i got a expensive montier that carrys like 144 hz or what not but i am useing a 1080p 60 hz kinda werid its having this much of a problem.
Been trying for a month emailing there tech support no answer i finely got there number but its the weekend got to wait till tomorrow when there open so i can call. As for pic and video i can't really do a pic on ghosting blur video i don't really have anything to do it with but i did how ever have found a video on youtube with the exact problem i am having https://www.youtube.com/watch?v=rbxOK4VLXZQ
