Question Ghosting?
Mar 8, 2019
  • Graphics Card
Radeon RX 570 series
  • Operating System
    • Windows 10 64bit
  • Driver version installed
    • 19.1.1
  • Display Device
    • element ELEFW2417M 1920x1080 @60Hz DVI-DVI cables
  • Motherboard + Bios Revision
    • X370 Gaming X AMI UEFI Legal BIOS Version 5.2
  • CPU
    • AMD Ryzen 5 2600 6 Core 12 Thread
  • Power Supply
Thermaltake RGB 850W
  • RAM
    • 16GB
There is a trail of the object/shadow on everything that moves on my monitor. Not just in games, the mouse cursor has blur, windows that I move has blur, and I don't know how to fix it. No I don't think it is the monitor, I tried my computer with a different one and it still had the shadows. Any fixes/ideas? And if there is just a option to turn it off I can't find it.
Yes i have the chipset drivers installed. My GPU is 21 degrees c right now. I tried to perform a clean uninstall for the graphics driver and installed it again, multiple times. I have messed around with the Radeon settings a lot and can't find anything. Do you have any experience with the Radeon settings? Should i send a recording of the issue?
